View MLD Group Information
Use this procedure to display information about the groups configured in this device.
- Select IPv6 MLD.
- Select the Group tab.
Group Field Description
Use the data in the following table to use the Group tab.
Field |
Description |
IPv6Address |
Specifies the multicast group address that others want to join to. A group address can be the same for many incoming ports. |
Members |
Specifies the IP address of a source that has sent group report whishing to join this group. |
InPort |
Identifies a physical interface or a logical interface which has received group reports from various sources. |
Expiration |
Specifies the time left before group report expires on this port. This is updated upon receiving a group report. |
IfIndex |
